Short shifter options
Old 12-12-2010, 09:45 PM
Spencer51X's Avatar
Default Short shifter options
I've heard good things about Pro 5.0's and MGW short-throws, but was wondering does the brand really matter very much. Wouldn't an offbrand do the same thing, since it's just a shifter?
http://cgi.ebay.com/ebaymotors/93-02...item5196c4848e
I like $40 alottt more than $200!
Old 12-12-2010, 10:01 PM
HexT's Avatar
Nearly every brand has a little different design. They aren't all just the same thing rebranded. Find someone that has a Pro5.0 setup and compare it to a B&M Ripper. Very different feel.
I use a stock Hurst with a short stick and love it.
Old 12-12-2010, 10:24 PM
94transbird's Avatar
What do you mean each one has a different design? Can't really get any different than a rotating stick... only if you make it spring assisted or air assisted.
Maybe you mean just the length of the actual stick or the materials used. That would make it feel much different.
When I shortened the stick on my BMW it felt a lot different. Then when i replaced all the bushings in the shifter assembly it felt like a whole new transmission.
I think the design is the same but not executed the same.
Old 12-12-2010, 10:25 PM
cowboysfan's Avatar
how much quality comes with $40 ?
Old 12-13-2010, 04:28 PM
steveo_f8's Avatar
^not alot for $40.
Both the pro 5.0 and the mgw are good. I had a pro 5.0 and then went mgw, to me, alot better and tighter throws. Takes a little getting used to but no more missed shifts.
My vote is the mgw, the quality of the actual shifter is awesome, you can always use a longer shifter handle/stick if thats what you prefer.
Old 12-13-2010, 06:16 PM
Spencer51X's Avatar
what do you mean by quality? quality on a clutch, brakes, heads/cams, etc makes sense. would it just make a smoother shift basically? i was under the impression that the length and pivot point were the only things that made faster, smoother *****.
i figure for $40 i can try it, if it sucks, buy a better brand.
Old 12-14-2010, 12:30 AM
1BadAzzWS6's Avatar
Get the Pro 5.0 with Lou's Short Stick... you'll never look back.
Old 12-16-2010, 12:25 AM
squee's Avatar
Yea, you will...When you order the MGW.
I had the Pro 5.0 w/short stick and it was iight. The MGW is SOOO much nicer. WELL worth the money.
Old 12-16-2010, 08:38 PM
westtexasbuff's Avatar
MGW all the way. I've had every shifter you can think of, MGW is the best.
Old 12-16-2010, 08:42 PM
jc98ss's Avatar
if you don't get the mgw, you'll always wonder how much better it REALLY is......i've had several, and the mgw REALLY is better
Old 12-16-2010, 08:53 PM
atrain59's Avatar
This i have had my MGW for about 6 months and love it
Old 12-17-2010, 06:57 PM
gm_jim's Avatar
Agree
Old 12-17-2010, 08:26 PM
mean_greenZ's Avatar
Stock hurst and umi short stick works great for me.
Old 12-17-2010, 09:40 PM
NBM99SS's Avatar
Pro 5.0 with stock pro 5.0 stick. Keep that leverage for better shifts. Short stick made my shifts feel horrible
Old 12-19-2010, 01:45 PM
PSJ
PSJ's Avatar
I use a stock Hurst with the Lou's Short Stick....works perfect.
Old 12-19-2010, 01:50 PM
CJJones87's Avatar
Also interested in what you guys are using. I have a aftermarket Hurst with WS6Store short stick now. I had a Pro 5.0 before this and I must say I like the 5.0 better. I'm considering getting an angled UMI short stick for the Hurst (I really liked how the Pro 5.0 angled the stick towards you), or just buying another Pro 5.0, or possibly an MGW.
Old 12-20-2010, 06:51 AM
demarco313's Avatar
MGW by far!!! Anybody whose recommends anything else other than the MGW has obviously NEVER used the MGW before! I bet anybody that has installed/used the MGW shifter has never contemplated taking it out to try another brand. YES it is that good and well worth the money. Its BY FAR the best shifter out there. Really short throws and NEVER missed a shift with it since its been installed and it has excellent quality
Old 12-20-2010, 07:26 AM
StoreKeeper99Z28's Avatar
Thumbs up
That's what I have and it's Great
Rx Bruce/StoreKeeper99Z28
Old 12-20-2010, 02:52 PM
squee's Avatar
I'd have to agree.
Old 12-20-2010, 11:46 PM
longshore98zls1's Avatar
I bought this exact same one about 7 or 8 months ago and it works fine but they could have made it shorter. It only made a 1 inch difference in height when compared to stock and felt just like the stock shifter but slightly shorter.
Now I'm moving up the MGW which is TEN times better by far. U know which gear your in everytime and never miss during your WOT throw towards 3rd. My buddy has one and it blew my mind. NO JOKE
Quick Reply: Short shifter options
