Bruteing
Old 12-13-2010, 12:46 AM
VandykeT/A's Avatar
Default Bruteing
Ok on a buddy of mines car when you yank it from 3rd back 2nd and get on it it'll brute the back wheels and then take off. What could cause this? Its a 86 camaro with a swapped in 6 speed. Hes running a Ram powergrip clutch.
Old 12-13-2010, 09:57 AM
85MikeTPI's Avatar
Might want to describe your problem another way??
bruteing- no dictionary results
brute –verb (used with object), brut·ed, brut·ing.
to shape (a diamond) by rubbing with another diamond or a diamond chip.
I'm not sure what the car is doing to the back tires after a 3->2 downshift and going WOT..
Old 12-13-2010, 12:44 PM
VandykeT/A's Avatar
Oh sorry redneck dialect kicking in. The back tires will slide for a second before it starts to pull hard when you pull it back to second. Like you just down shifted at high rpm with out using throttle but your flooring it. The drivetrain brings the motor down for a second and then the car takes off.
Old 12-13-2010, 12:48 PM
KevinR's Avatar
So...He is going from 3rd to 2nd, nails it, and the tires break loose? Am I not understanding this completely?
Old 12-13-2010, 08:01 PM
VandykeT/A's Avatar
He is going from 3rd to 2nd, nails it, and the rear wheels slide instead of spin.
Old 12-13-2010, 08:07 PM
Tx91z28's Avatar
i believe thats called downshifting without rpm matching and ******* your **** up - cuz your locking your rear wheels up with your drivetrain and not your breaks. like hitting 2-3-2 instead of 2-3-4.
Old 12-13-2010, 08:15 PM
1CAMWNDR's Avatar
He needs better foot work. He should have the engine reving higher when he dumps the clutch in 2nd gear. Not dump the clutch with the throttle closed, then floor it.
Old 12-14-2010, 10:15 AM
dutinsss's Avatar
get the rpms up and THEN dump the clutch. you can't just be at idle rpm, floor it and dump the clutch instantly. have to let the rpms raise first.
Old 12-14-2010, 11:52 PM
VandykeT/A's Avatar
I kinda thought that could be it but i thought i'd ask in case something in the drivetrain would cause that. Thanks
