Will a 5/8 bore Clutch Master work??
I am doing a swap and my truck currently already has a 5/8 bore master cylinder, and I know the Camaro uses a 3/4, has anyone use a 5/8 and does it push enough volume to disengage the clutch??
Just want to know before I invest the time to adapt it...I have the stock Camaro master cylinder but it the line is broken on the trans side @ the disconnect..
So I would like to just adapt to the Toyota master but not sure it will work since it is 1 size smaller bore..
Help...
Help...
So I take it nobody has tried the clutch with a 5/8 bore on the master to see if it has the volume to disengage the clutch?
I was hoping to use the 5/8 Toyota master but not sure if I should even try it, dont want to do it if it isnt going to work, would just be wasted time, I guess I was hoping someone had been to this point I am at now to give some advice..
Oh well I guess it didnt hurt to try and ask..
