monster clutch weight info!
i just wanted to put this info out there since i just weighed my stage 3 monster clutch with chromoly flywheel 18lb. This is for people later looking for weight specs.
my stock ls1 clutch/flywheel assembly 49 lbs
ls1 stock flywheel with spec stage 3 puck 50lbs
My monster clutch stage 3 with 18lb flywheel 46lbs complete
there you go guys
there you go guys
The stock flywheel really isn't that heavy. It's only 23lbs. The pressure plate with my clutch (Diamond Clutch) is 2-3lbs heavier than stock & Monster appears to be the same way. Hence the reason for using a lightweight flywheel. It makes up for a heavier pressure plate and then some.
Any one of the Diamond Clutch complete kits (Stage 1, 2, or 3) comes out to 43lbs total.
If you were to use a stock flywheel or a heavier billet flywheel, it would be heavier than stock.
