Viper T56
Viper T56
Will the T56 out of a 2005 Viper fit a 2002 SS Camaro? It appears that transmission is not made by Tremec it has Borg Warner stamped on the side. I have a friend selling one with low miles for $2000 and want to make sure it will fit before I purchase it.
You'll have to change the front plate and machine the input shaft. If you're trying for a direct fit, you'll have to change the tail also.
For the most part, it's alot of work & $ and you don't end up with much more than if you started with a Fbody T56 and had a sponsor do a viper-spec upgrade to it..
We sell T56's fully built with the upgraded steel 3-4 shift fork and billet keys, one year unlimited mileage warranty for $1800 w/ out exchange. You can choose the close ratio or wide ratio gear set.
Or, if you're making 700+HP/TQ, we sell a "better than Viper" 31-spline T56 unit for $2500.
