t56 with stock long block 6.0
I got an 03 Escalade block (GENIII) in my car and everything bolted right up. If you stay with a GEN III block everything will bolt right up. If you go with a LS2 which is GEN IV I believe, I think the knock sensors and the cam position senors are in different locations or different plugs
^^^Correct. The 99-00 LQ4 crankshaft has a longer rear flange that can only be used with 4l80e/th400/th350 transmissions. A 4l60e or T56 will not bolt up to these engines. Starting in 2001 they went to the shorter flange that bolt right up to a T56. These early engines are easily identifiable by their iron cyl heads heads instead of aluminum 317 castings that came on the '01+ engines.
