Clutch pedal in, inconsisant grinding noise
Old 02-10-2011, 05:34 PM
bigb916's Avatar
Default Clutch pedal in, inconsisant grinding noise
I have a 00 M6 TA w/100k.
Recently I have noticed a grinding metal on metal sound coming from my clutch assembly area. It only happens at idle or about 1k-2k rpms, in gear or neutral, clutch pedal pushed IN.
The clutch was replaced by the PO 15k miles ago or so. It has no grinds or trouble entering any gears whatsoever. Just a super ugly noise that concerns me.
Throwout bearing maybe? any help is appreciated, thanks.
Old 02-10-2011, 05:59 PM
Build #1's Avatar
Was the Throwout bearing replaced? even if it was it sounds like thats your problem unless you have a broken pp finger or something.
Old 02-10-2011, 11:34 PM
bigb916's Avatar
When I got the car I asked the PO if the TO bearing was replaced. He wasn't sure since he had it done by a shop, and no documents of it being replaced.
If it helps, sometimes when I shift I get a "whirr" sound and vibration that comes through the shifter, but its only 25% of the time.
thanks
Old 02-11-2011, 08:19 AM
Build #1's Avatar
Time to pull the transmission and inspect slave and clutch.
Quick Reply: Clutch pedal in, inconsisant grinding noise
