Car runs in 5th gear. - LS1TECH
Thread Tools Search this Thread
Old 02-18-2011, 06:31 PM   #1
Pretyflywiteguy's Avatar
Angry Car runs in 5th gear.
1994 LT1 T56...
I shifted into 4th at about 3K and heard a pop. The shifter shifts smoothly into every gear, the clutch pedal feels the same, there is fluid in the resevoir, The car can sit and idle while in 5th gear. I can hear something a ssshhh sounding scraping noise while its in gear. Kind of at a loss for words right now, I was on my way to a job interview. God hates me, I sat in an ant pile while I waited for the tow truck...
a little help?
Pretyflywiteguy is offline   Reply With Quote
Old 02-18-2011, 06:36 PM   #2
85MikeTPI's Avatar
Does it freewheel in 6th gear also? Sounds like the 5-6 cluster has spun through the splines on the mainshaft. If Reverse is gone too, then you probably sheared the lugs off of the countershaft that turns the 5/6/R extension
85MikeTPI is offline   Reply With Quote
Old 02-18-2011, 07:42 PM   #3
None of the gears work. The motor just revs while it's in gear.
Old 02-18-2011, 07:46 PM   #4
85MikeTPI's Avatar
Quote:
What's the special problem in 5th gear?
Old 02-18-2011, 10:09 PM   #5
Nothing special, just the gear I happened to put it in while it sat idling. Fourth was the gear that I was shifting to when whatever broke, broke. Basically, the car can sit and idle in any gear as if it were in neutral. all the while making a spinning scraping sound.
Old 02-18-2011, 10:45 PM   #6
Sounds like a clutch issue to me
sxracerb25 is offline   Reply With Quote
Old 02-19-2011, 08:22 AM   #7
85MikeTPI's Avatar
You most likely separated the hub from the disc on the clutch plate. Pull the trans and inspect the clutch disc to be sure.
Old 02-19-2011, 01:56 PM   #8
PACKERSz28Camaro's Avatar
clutch. Similar thing happened to me a few years ago. I thought the worst but it was only the clutch.
PACKERSz28Camaro is offline   Reply With Quote
Old 02-19-2011, 02:38 PM   #9
do I need to drain the transmission fluid just to inspect the clutch? I'm aware the tranny needs to be dropped. simple yes or no will suffice.
thanks.
edit: Drained it anyway..
Tags
5th, car, gear, runs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
