Tick Master Pedal Install Instructions??
Old 02-18-2011, 05:56 PM
eddielb's Avatar
Default Tick Master Pedal Install Instructions??
A while back I ordered and installed a tick master, but it came with no instructions, car was getting a new rear end but now im ready to finish the Tick Master Install
how do I adjust/install the actual clutch pedal? Do I make the rod the same lenght as the stock rod, or do I make it longer/shorter? Then tighten the jam nut? I see everyone says adjust according to instructions but mine from ws6 store didn't come with instructions Thanks !
Old 02-18-2011, 06:06 PM
therealcreeper's Avatar
start with the pedal low, run car in neutral and try to get into gear. if it doesn't go in easily bring it up a tad and try again, until it goes into gear nice and smoothly
then go find a nice level surface and put the car in first gear, clutch pushed all the way in, and with no brakes or e brake rev to 6k rpm. if the car begins to move at all raise the pedal slightly and try again until it does not lurch
Old 02-22-2011, 02:44 AM
scidav87's Avatar
Exactly, but MAKE SURE not to go more than than or you could over-extend the slave causing pressure plate damage.
