GTO T-56 Model #?
GTO T-56 Model #?
I'm needing to find out the model # on the GTO T-56, I've got something I'm needing to track down and don't have the trans handy just to look at it.
I'm working on a trans swap and the shop told me of two different Holden based T-56's, and the two input shafts that will be compatible with my build.
T56 model #'s with corresponding input shaft model #'s:
TUET6000 needs an input shaft from a TUET2100
TUET6300 needs an input shaft from a TUET2066
Anybody able to help me decode this?
The TUET2066 is the M12 GTO normally found in the US. The 2100 is the aussie MM6 equivalent of the GTO. The 6000 and 6300 are aussie versions that have the same gear sets as the listed counterparts, but with shorter input shafts.
As far as lengths go, the TUET2100 should have the same input shaft as a base (non-Z06) C5-T56.
