4l60e to t56 magnum
4l60e to t56 magnum
i want a trans am m6 but the ones i want i can only find in automatics. can someone help explain how to change out a automatic for a t56 magnum? please inform me of anything i would need to do to change it out and pictures only help. if i get a t56 ws.6 i was going change it out for a t56 magnum anyway. can anyone help me? thanks.
There is a lot of good info about the conversion in the thread above. When you are ready for a Magnum let me know. We offer a T56 Magnum that will bolt into your Trans Am that will require ZERO modifications. It uses the OEM style shifter and has torque arm provisions, and factory speedo sensor.
Let me know if you have any other questions.
4l60e, 4wd, 60, 77, change, conversion, convert, converting, ls1tech, magnum, swap, t56, trans, transmission, underrated
