Diamond Stage 1 & dowel pin question
I'm trying to install a Diamond Stage 1 (Luk) on my re-surfaced LS1 flywheel, and the pressure plate does not have any holes for the 2 dowel pins in the flywheel. Do I just remove the dowel pins & bolt it up? The bolt pattern is correct. The pic of the PP here doesn't show dowel pin holes either.
i just marked and drilled holes into my clutch. before i did it i called jason at TDP bc i was afraid it would through off the "balance" of my clutch. jason said that it would be ok, so i drilled mine to match the pressure plate and it works perfect.
i did it this way bc i didn't want to remove my "torqued" pressure plate for a third time. now, if i had the PP off the block i would have removed the pins.
