LS2 to son of tranzilla clutch question
Old 03-03-2011, 10:51 AM
Baynut's Avatar
Default LS2 to son of tranzilla clutch question
Hey, well I have most of my parts for my swap. I have an 78 T/A with an LS2 from a '06 TBSS (yet to be installed) and just got a smoking deal on a second hand but never used t56 son of tranzilla. When I got the t56 it came with hydro bearing and a new RAM clutch and steel flywheel #90-2135. Last owner was going to set it to a BBC. So my questions are, what slave/master should I use and what pilot bearing. Also would the flywheel work ok, I haven't checked yet but based on what I was told because it was for a BBC I might have to "stretch" the bolt wholes for the flywheel. I would rather use what I have then buy a new flywheel and clutch. Thanks.
Old 03-05-2011, 07:33 AM
Baynut's Avatar
Anyone?
Old 06-02-2011, 11:33 AM
Baynut's Avatar
Looking at the auto flywheel vs the the ram one I might need a spacer and elongate the bolt holes. Has anyone used a spacer on pressure plate before?
Quick Reply: LS2 to son of tranzilla clutch question
