T56 spacer and thrust washer questions - Overhaul
Old 03-09-2011, 03:23 PM
steve000's Avatar
Default T56 spacer and thrust washer questions - Overhaul
Where do these spacers/ thrust washers go...
I think the thin one is the part 68 (thrust washer) that goes on the reverse syncro. I'm missing either the spacer 115 (near 6th) or thrust washer on the back of the reverse 74.
Old 03-09-2011, 03:28 PM
85MikeTPI's Avatar
The thin one goes on the rev synchro, side facing the Rev gear.
The thick one goes on the mainshaft, right after the Rev gear goes on and is held on with a snap ring.
The "115" 6th gear spacer is a small silver ring that protects the 6th gear plastic needle bearing from getting chewed up on the 5/6 synchro snap-ring. It's the same diameter as the needle bearing.
Old 03-09-2011, 03:33 PM
steve000's Avatar
Thanks Mike
Old 02-11-2012, 06:17 PM
jeeperanthony's Avatar
Whats the part number/name for the thicker piece?
Old 02-11-2012, 11:46 PM
jmd
jmd's Avatar
Mainshaft Reverse Gear Thrust Washer (Rear)
Quick Reply: T56 spacer and thrust washer questions - Overhaul
