Parts on clutch install?
Old 03-11-2011, 07:32 PM
formulafast's Avatar
Default Parts on clutch install?
I am doing my monster stg. 2 clutch, tick master, slave, and speed bleeder install tomarrow. what is everything I will need to do this parts wise i.e. fluids, gaskets... stuff like that it will be my first clutch so I would like to know. Thank yoiu
Old 03-11-2011, 09:01 PM
KTK Z28's Avatar
I would consider changing the rear main seal and the pilot bearing. It's not 100% necessary, but while your in there its a good idea to change it. They are relatively inexpensive to get from the dealer.
Old 03-11-2011, 10:35 PM
therealcreeper's Avatar
-pilot bearing (will probably need blind hole puller tool, do not use hyrdaulic/bread method)
-rear main seal if necessary
-red loctite for flywheel to crank and pressure plate to flywheel bolts
-anti-sieze for bellhousing to block and trans to bellhousing
-4 quarts of ATF (you will be draining yours before you pull the driveshaft off)
-RTV silicon to seal shifter back on (unless you have pump to refill trans though fill hole)
-dab of grease for input shaft tip and splines
