Tick speed bleeder install
Old 03-12-2011, 04:34 PM
sillysspeed's Avatar
Default Tick speed bleeder install
Has anyone been able to install the speed bleeder without dropping the trans. I was under there today and the only thing I can think of is to modify a socket to fit but even then it seems like it would be a long shot... thanks in advance
Old 03-12-2011, 08:36 PM
KTK Z28's Avatar
I think your going to have a pretty difficult time with that. It may even be impossible to do. Dropping the trans actually isn't that big of a deal. You can probably get away with just sliding it back on the main shaft a little to get to the slave (leave the bell housing on).
Old 03-14-2011, 07:39 PM
Build #1's Avatar
Impossible.
Old 03-14-2011, 10:41 PM
Sargeant Sh!tbag's Avatar
Nothing is impossible.. Just cut a huge hole in the trans tunnel for easy access!
Old 03-15-2011, 12:22 AM
TransWS6Am's Avatar
im going to go with impossible also, i have the remote bleeder on my t-56, i don't see how you could get it on the slave without dropping the tranny.
Old 03-15-2011, 11:10 AM
FST SS's Avatar
I tried and ended up having to cut a hole in the floor board just to get the OEM bleeder back in.
Old 03-15-2011, 12:12 PM
2002nbmss's Avatar
Just wondering, but are you installing a new clutch or something? Why are you concerned with installing the speed bleeder if you don't have the trans out anyways? If you don't have any issues with your clutch now, then i suggest waiting till it's new clutch time and then install the speed bleeder because the trans has to be out or at least slid back enough to install it.
Quick Reply: Tick speed bleeder install
