RIddle me This
Old 03-21-2011, 05:51 PM
1'low92's Avatar
Default RIddle me This
my clutch keeps dropping to the floor when the car sits.... ive bled it over and over.... i had a new slave and a tick master...and also speed bleeder and clutchn is monster stg 3 all components are under 1000k old all bought when i changed the clutch .........i ve bled it the normal way and bled it using a hand bleeder can any one help me understand if im missing something....any answer will be greatley appericiated.
thanks Steve
Old 03-22-2011, 08:51 AM
calhoon's Avatar
unfortunately the answer is simple physics. You have no hydraulic pressure. That means there is air in the system or an internal seal leak( This assumes ther is no leak to the outside). It can be most difficult to fully evacuate the air in these systems. Since you have new components I would lean twards air in the system remains.
Old 03-22-2011, 10:39 AM
sleepy_z's Avatar
How long does the car sit before the pedal drops?
Have you noticed any leaks?
Old 03-22-2011, 03:20 PM
1'low92's Avatar
could be a couple hours
and theres is no leaks im wodering if that speed bleeder is seeping air or did the brand new tick master go bad or the new slave take a crap im lost on this one.....
Old 03-22-2011, 03:33 PM
disc0monkey's Avatar
did you put the washer on the remote bleeder to the slave?
Old 03-22-2011, 03:35 PM
NufNuffZ28's Avatar
When mine did that it was the slave
Old 03-22-2011, 03:44 PM
1'low92's Avatar
im not sure about the washer its been a while since i installed it but if it needed to be there its on it.... the rear broke about 500k after clutch and component install
Old 03-22-2011, 10:54 PM
Sargeant Sh!tbag's Avatar
1: The remote bleeder line should not have air inside it.
2: If it has air come out of it when you depress the pedal and open the valve continue the bleeding process.
3: If you did not install the washer on the remote bleeder you would know bc it would slowly but surely leak fluid.
It sounds like the MC is allowing fluid around the ram seal. That is the only answer if you are 100% sure it is not leaking anywhere and there is no air in the system.. Test this theory by depressing the clutch petal to the floor and hold it there after you have good pedal pressure for several minutes.. If your pedal does not come all the way back with good pressure it is leaking past the seal in the MC, there is air in the system, or you have a leak.
Try checking these things and tell us what you come up with.. It might also be a good idea to place cardboard underneath the car to make sure a leak would easily be spotted by the dripping fluid on the paper surface.
BTW, just helping you out here for future posts.
1000k = 1,000,000
500k = 500,000
1k = 1000
.5k = 500
Old 03-23-2011, 03:58 PM
1'low92's Avatar
yea ill try that ... people with the tick adj master how did you properly adjust it ...i had it good and tried to re adjust aND THE pedal reaeses to high
Old 03-25-2011, 05:34 AM
1'low92's Avatar
bump..
Old 03-27-2011, 05:21 PM
1'low92's Avatar
Ok i bled the clutch again.. got all air out... the pedal was up then i went back in the garage about 30 min later and the pedal was on the floor...i dont see any signs of fluid leaking ....what should i try now?
Old 03-27-2011, 05:24 PM
There's guide somewhere...
Old 03-27-2011, 05:25 PM
A leak on phone
Quick Reply: RIddle me This
