Just Installed B&M Ripper...
My buddy and I installed the B&M Ripper Shifter on his '02 WS.6 lastnight. He had the factory Hurst with the Quickstick. The install went smoothly. Now he says he is hearing some sort or banging noise (not quite sure how to describe it b/c I havn't heard it yet) when he puts the car into gear. Is this because the shifter plate needs to be adjusted or what? Any help would be appreciated, thanks.
P.S.
I am not thrilled with the B&M because I was under the impression that the throws would not only be a little shorter, but that the shifter would feel very very firm. The throws are maybe shorter if you are going from the stock Hurst shifter, but with the Quickstick, the stock Hurst feels as short if not shorter. An upside to the B&M however is that it's very smooth.
P.S.
P.S.
P.S.
Did he intall the stops?
I don't even use them , I rebuild these trannies and they have built in stops.
Tom
It really depends on what kind of noise you are talking about? The ripper rattles more than the hurst. You can hear the clicking of the gear changes inside the car through the shifter too. The rubber insulator on the stock hurst stops the noises, but you have less of a feel of what you are doing.
My buddy said that it is not just more "road noise" or "Transmission and engine noise". He described it as a bang when he pushes the clutch in. We are going to try and adjust it a tiny bit and see if that helps.
Figured out what the problem was. It just so happened to be my friend's rear end making noise because it is "blown". It was coincidental that it started making noise after the install of the B&M Ripper. He is returning the ripper anyway because he didn't like the fact that the stock hurst with quick stick was shorter and also because he needs money right now to buy a 12 bolt.
Originally Posted by Bugsquawsher
Save your tranny
Take the Stops out and Toss them in the trash.
-Ashton
My car came with the B&M installed and I was wondering if it is supposed to have the black boot on it. There is the leather one that you can see, then another one under this. I thought I heard this was supposed to be remove. Anyone know? Thanks.
Here's a pic, look right?
I bought my car with the B&M shiffter. My question is where are the stops located (i dont know if this might be the prob but sometimes when i shift fast the trany will grind alittle). Thanks for your time.
the little mini boot on the shifter protects the shifter from debri(dirt) flying from under the car. the big boot in the picture keeps the dirt/water/noise/etc from the inside of the car. trust me that little square piece of rubber makes a hell of a difference in road noise.
S
S
Are you sure your not just rowing the gears a little sooner than your dis-engaging the clutch(quick shifting but slow clutching)? I know I've done it a couple times.
