Spec aluminum PP torque specs?
Looking for the torque specs for the aluminum Spec pressure plate. Did you use the bolts that came with the Spec, or ARP?
Thank you
Thank you
I assume that you are referencing the pressure-plate to flywheel bolts...correct? If so, our kit requires OE torque specs. We include bolts with our flywheels so I assume you have one of these too. Yes, you should use the bolts that are included with the kit.
