RP Synchromesh change interval?
Old 04-02-2011, 11:16 AM
bayer-z28's Avatar
Default RP Synchromesh change interval?
I was going to change my trans fluid since my second gear wasn't engaging as easily as it used to. It took a second to get in until the fluid was warmed up. Normally I'd just leave it in second for a while to get the fluid sloshing around real good and then it seemed fine.
This is a T56Rebuilds Micronite and carbon fiber 4B package with about 25k-30k on it. No problems otherwise but the current RP Synchromesh fluid has about 10k miles on it. I have two fresh quarts of fluid. I was just gonna drain a quart and a half out and refill it w new stuff.
Ideas?
Old 04-02-2011, 12:42 PM
thesource's Avatar
I wouldn't waste the time or fluid. 10K isn't enough milage to worry about changing it. I would however check the level and top off as needed.
Old 04-02-2011, 08:07 PM
bayer-z28's Avatar
^ Ahh.. Ok.. thanks. .I was thinking the RP oil shouldn't be even close to being worn yet.
