replace clutch but its really hard to put the gears in
Old 04-04-2011, 01:03 AM
droptopT/A's Avatar
Default replace clutch but its really hard to put the gears in
hey guys and gals i just replaced the clutch on my 99 transam with a monster stage 3 kit,new master,new slave,new bolts,did the drill mod and put the speed bleeder on it.tbut the gears are very hard to go in; i been bleeding it like crazy but it doesnt help what could be wrong, the car moves a little when its in first gear with the clutch all the way pressed in.when i drive it the gears are alittle hard to go in but they go in.
Old 04-04-2011, 01:39 AM
2000ls1tranz's Avatar
get a tick master adj. cyl. it should solve ur problems i have the same clutch an with the tick master...works awesome
Old 04-04-2011, 02:06 AM
droptopT/A's Avatar
i wish i could but i already bought the new gm master and i really dont have the cash for a tick
Old 04-04-2011, 02:21 AM
yea i understand..but u are probley stuck with the problems till u do..
Old 04-04-2011, 08:15 AM
Nmbr1GMfan's Avatar
Is the clutch disengaging properly? Did you do the rev test in first gear?
Old 04-04-2011, 08:46 AM
wrd1972's Avatar
Yup.
Old 04-04-2011, 10:13 AM
Matt@SNLPerformance's Avatar
Give us a call and we can go over a few things.
Old 04-04-2011, 10:36 AM
droptopT/A's Avatar
What's the rev test and how do u do it?
Old 04-04-2011, 12:29 PM
Nmbr1GMfan's Avatar
On flat ground with the car in first gear clutch pedal pressed to floor rev engine to 5-6k. Does the car creep forward? Or on a hill car not running in first gear slowly push the clutch in, where in the pedal travel does the car start to roll?
Old 04-04-2011, 12:43 PM
stoverz28's Avatar
You dont need to rev the car to 5 or 6k... Just put it in gear and see if the car moves.
If you cant afford the tick then this thread might help you out.
https://ls1tech.com/forums/manual-tr...r-writeup.html
Either way if you keep driving the car like that your trans will be needing a rebuild soon...
Quick Reply: replace clutch but its really hard to put the gears in
