T5 on a 5.3 help
Old 04-07-2011, 10:16 PM
lt1chevelle's Avatar
Default T5 on a 5.3 help
has anyone mounted a T5 to a 5.3? i am doing an ls conversion on my c10 an i am running a 5.3. i already have the t5 an would like to know if anyone makes an adaptor plate or is this not possible?
thanks
Old 04-07-2011, 10:35 PM
jmd
jmd's Avatar
Is it from a 1983 AMC Jeep?
Old 04-08-2011, 06:47 PM
no its out of a camaro
Old 04-08-2011, 08:16 PM
85MikeTPI's Avatar
A 1994 camaro?
Old 04-08-2011, 08:59 PM
bayer-z28's Avatar
Check D&D transmissions and see if they have an adapter bellhousing. If you had the money I wouldn't bother with the T5.
Old 04-08-2011, 09:06 PM
thesource's Avatar
I wouldn't waste the time or the money on putting a T5 into a full size truck.
Old 04-08-2011, 09:08 PM
bayer-z28's Avatar
^ I was gonna say something similar, but I didn't want to be too harsh. But in a truck, it may be ok depending on gear choice and tire height. But the T5 has a horrid RPM dropoff and with 4.11s it may top out at about 95 in a car. -My buddy found that out the hard way in his Fox. Never saw a T56 in a truck though.. That'd be pretty cool for a muscle truck.
Old 04-08-2011, 09:46 PM
thesource's Avatar
Not to mention a truck is about 1000 lbs heavier than most cars the T5 came in from the factory. Thats going to decrease its torque capacity.
As for the T56 in a truck issue, Dodge came out with one years ago called the SRT10 Viper truck. I have seen a Lightning with a T56 and even sold a T56 to a guy putting one into a Suburban with 33" tires!!!
Old 04-09-2011, 08:25 AM
85MikeTPI's Avatar
And lets not forget the T56 equipped SSR truck...
Old 04-09-2011, 09:53 AM
bayer-z28's Avatar
^ Oh cool.. I've never paid too much attention to the transmissions in those trucks.
Old 04-09-2011, 10:55 AM
jmd
jmd's Avatar
Post
I've been 140mph with a T5 and 3.73s. You may want to figure out what's wrong with that engine.
You might want to determine what year and engine because there are at least 2 bellhousing patterns, 2 input lengths, 2 spline count/sizes and a whole lot of different gear ratios depending on which one it is.
Everything can be made to work. You're providing enough information to determine absolutely nothing. There's a 1352-xxx number on a decal up top or on a metal tag at a tailhousing bolt that would help enormously.
Old 04-11-2011, 02:41 PM
garys 68's Avatar
What year camaro? Was it a V6 or V8?
Similar details on the motor would be helpful, and what type of clutch linkage do you want to run, C10 mechanical or camaro hydraulic?
Quick Reply: T5 on a 5.3 help
