Clutch installation
Old 04-10-2011, 10:25 PM
Egg1456's Avatar
Default Clutch installation
When installing a clutch and flywheel after you torque to proper settings are you supposed to tighten the bolts further like 90 more degrees or something?
Old 04-11-2011, 03:49 PM
Sargeant Sh!tbag's Avatar
NO! There is a tq spec listed in the paperwork that came with your clutch. Do not exceed those numbers.
Old 04-11-2011, 04:11 PM
SNLPerformance's Avatar
Flywheel bolts are torqued in three phases, the torque specs are 15-37-74 ft/lbs of torque. The torque sequence is 1-4-6-2-3-5
Pressure plate bolts are torqued in three phases, the torque specs are 20-40-52 ft/lbs of torque. The torque sequence is 1-4-6-2-3-5
Old 04-11-2011, 04:34 PM
Egg1456's Avatar
alright thanks guys thats the how installed it originally, I was gonna take it out and look at it to check for wear.
Old 06-21-2011, 01:59 PM
peterock98's Avatar
Do you need to loctite the pressure plate bolts ?
Old 06-21-2011, 02:46 PM
ssdeuce74's Avatar
i never have on stock applications, but sure it wouldn't hurt
