98 t56 with a LS7 clutch and throwout?
Old 04-13-2011, 04:38 PM
johnyrrr's Avatar
Default 98 t56 with a LS7 clutch and throwout?
So I have the 1998 LS1/T56 setup that I am putting in a mustang. The stock clutch was fried as was the PP, so I bought a LS7 setup and am trying to put it into the T56 an tried to plug in my braided line from the master to the LS7 Throwout(see pic) and the connection to the throw-out bearing is different. My question, should I just use a stock Ls/T56 throwout that connects to my old line with the LS7 clutch or is there a new line that goes from older clutch master to the newer type LS7 throwout bearing to uses with LS7 clutches? Sorry for the newbie question
Old 04-13-2011, 04:56 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Use a stock LS1 Slave and throwout bearing
Old 04-15-2011, 09:14 PM
the_merv's Avatar
Ya it needs to be Fbody or GTO Slave.
Old 04-16-2011, 06:53 AM
johnyrrr's Avatar
good deal guys
I will get a new slave/throwout.
Quick Reply: 98 t56 with a LS7 clutch and throwout?
