2nd Gear Grind
2nd Gear Grind
I just pulled the car out of storage, and on my first WOT run grinded 2nd gear twice I never grind 2nd gear.. So what gives?
I have a Textralia Z grip with maybe 3,500 miles on it.. My car isn't a DD, jsut a cruiser basically
Any ideas??
Any ideas??
If it's a clutch or hydraulic issue, then it will be hard to get into first and reverse. If it's just grinding 2nd gear, then it has to be something internal [2nd gear engagement teeth, slider, and/or ring(s) worn]. It could only be a coincidence as it just happened to start messing up after taking it outta storage. If this is the case, inevitably, you'll need a rebuild/upgrade. Check my sig for rebuild info/website info.
