Need some quick help with my clutch hydraulics... (installing new master cylinder now
I just finished putting in a new clutch, and a shop installed a new slave cylinder a week ago, right before I took it apart myself. I'm putting everything back together right now, got the new master cylinder in, tried to bleed it out, but I got zero pressure on the clutch pedal after several bleeding attempts. Fluid was coming out the bleeder valve each time I bled it, but still no pressure.
The thing that concerns me is that I was under the assumption that with the master cylinder hydraulic line disconnected from the slave, you shouldn't be able to push the cylinder in. However, I can easily push the piston in by hand. Could this mean my brand new cylinder is bad out of the box?
What could be the problem? What else should I check for? The only thing I can think of is that I did the drill mod on the cable while I had it out. I was careful to keep the cable straight, but maybe I somehow nicked the inside and broke a small hole in the cable? I'd think I'd see fluid leaking out of the cable though when I pump the master... plus I can blow air into the cable and it doesn't leak... although it may take more pressure than I can apply.
If what Blwn_by_Twins says is true though, I've got a problem with the cylinder or hydraulic cable though. I just went and exchanged the cylinder for a new one, so I'm going to try and connect the cable up to the new cylinder and pre-bleed it, and see if I get pressure on just the master.
^^if that was towards me
I couldnt push it down so I assumed it had to be hooked up. I got under the car to push the inner plastic back and my friend got in and pushed it really hard....before i got to push the plastic in. So the **** got all over me lol. The o ring came half way, out. Pushed the ring back in and the clutch pedal moved as if it were hooked up.
Master and hose are out of the car now. I posted a topic about the hose
So that may have been the reason I was getting no pressure once everything was back together???
I dont wanna jack this guys thread, Can you check my post out?
https://ls1tech.com/forums/manual-tr...ual-trans.html
question, do you put the car up on jack stands?
also, i talked to a guy about my master pssoibly being bad and he was saying something about jacking up the front of the car to get something.......the call cut out, but i think hew was refering to bleeding it.
any body know? i may just call him back.
Bench bleeding and cutting a hole next to the gas pedal. Make sure the hole lines up with the bleeder. You can pump the clutch and turn the wrench all while in the car.
I have mine off the ground. You will need to be able to get under the car and still be able to work from the top, under the hood.
Search for the drill mod too. you will wanna do that too
