Losing clutch pedal after a few hundred miles.
Hey all,
I was having the usual problems of the clutch sticking to the floor, high rpm sticking, blah blah blah. I put in a Tick master and that made the car 100 times more fun to drive. It shifted beautifully under every condition. Now, i'm starting to lose pressure again. Its nearly impossible to get into gear, reverse I have to turn the car off, put it in gear, then turn it on, and even with the clutch to the floor, it rolls like its engaged. So, I'm obviously loosing pressure.
I bought a new clutch, but haven't put it in yet, so I figured I would put that in and see how it is. My question is, what do you think the problem is? The slave cylinder was replaced about 5K miles ago, do you think that's the problem? I doubt the master is the problem since it's brand new, but I guess it could've sprung a leak somehow.
Any advice would be greatly appreciated guys.
