Is a performance shop needed for a clutch install?
Old 06-24-2011, 05:05 PM
BigBadVoodoo Daddy's Avatar
Default Is a performance shop needed for a clutch install?
So Im about to get my clutch and slave cylinder installed in my 00 M6 Camaro Z28..........my question is do you think I need a performance shop to install a Spec stage 3+ and a slave cylinder, or would I be fine getting my normal mechanic to install it? I mean is a clutch install pretty much a clutch install?
Old 06-24-2011, 08:50 PM
anybody???
Old 06-24-2011, 09:15 PM
sweetride98's Avatar
I did my own, I installed a Tick adjustable master cylinder new slave cylinder and centerforce dual friction clutch, not much different than install oem. I would think if you have a mechanic you trust it wouldnt make a differnce
Old 06-24-2011, 09:46 PM
Quick Sh0t xMLx's Avatar
I don't see why your regular mechanic won't work. As you said a clutch swap is a clutch swap.
Old 06-24-2011, 10:03 PM
thanks guys
