No 4th gear
Old 06-24-2011, 10:50 PM
b00ya's Avatar
Default No 4th gear
I just finished my build with an LQ9/t56 combo 98 formula. Just installed a brand new spec stage 3 and started driving the car to find out it wont ever go in 4th gear, it just grinds and will never engage. With the car off I tried putting it in 4th, stick stays like its in gear but you can push the car and feel it grinding on the stick. Its a trans out of a junkyard with a warranty so Im not at a total loss but I don't wanna have to pull it if it could be a simple fix with hydraulics or shifter, its a stock hurst shifter with a short stick. Am i screw and have to pull it or is there another way?
Old 06-25-2011, 06:51 AM
jmd
jmd's Avatar
If it never worked before and that shifter doesn't have adjustable stops, you may as well pull it.
Old 06-27-2011, 07:26 AM
Jeremy@RPMTransmissions's Avatar
Sounds like the synchro keys are broken. It is a very common failure in the T56 transmission. If you've got a warranty it's definitely time to take it back.
Old 06-28-2011, 03:03 PM
b00ya's Avatar
They are shipping me a new one should have it next week, if the new one works fine and they dont ask for this one back itll be up for sale if anyone needs a core.
