Mcleod RXT and Tick master?
Old 06-27-2011, 03:21 AM
ss2000's Avatar
Default Mcleod RXT and Tick master?
I saw on here that the Tick master shouldn't be used with the RXT clutch. I just got mine together and it grabs right at the top. I'm going to re-bleed it but I'm not sure if I should put the stock master back in. Any thoughts? I did measure for a shim and it looked ok. Thanks.
Old 06-27-2011, 08:03 AM
jmm98LS1's Avatar
I run the tick master & RXT. Mine also fully engages fairly high in the pedal travel, but I prefer it that way. I've only got about 75 miles on mine so far but am absolutely loving it!!!
Old 06-28-2011, 08:54 PM
WS6 SRT-8's Avatar
RXT and Tick here also. I measured and didn't need a shim either. Just
adjust the master correctly and I don't believe you'll have a problem.
Old 07-06-2011, 04:17 PM
LS1TECH Sponsor
Joey@Tick's Avatar
Plenty of Mcleod Twin/Tick guys here without issues.
Old 07-06-2011, 05:35 PM
SNLPerformance's Avatar
Even though this isn't a Monster, I'll chime in.
The Tick master, when adjusted properly, will work with any clutch.
The important thing is the adjustment; improper adjustment will absolutely destroy any clutch - proper adjustment will absolutely compliment any clutch!
Quick Reply: Mcleod RXT and Tick master?
