What Flywheel for Spec stage 2?
Picking up a spec stage 2. What flywheels will work for it? Will a stock ls1 FW work?
Also, the guy is throwing in a slightly used Fidanza 6 puck, will that be compatible with the spec pressure plate?
One last thing, who's got the best price on a pro 5.0? I got my t-5 one off ebay and it's the best shifter IMO
Thanks guys
Thanks guys
We sell a Billet 28lb for $300 or an 18lb for $350. You can use a stock flywheel resurfaced, but it may require a shim to compensate to get proper disengagement. Again you can't just mix and match discs as thickness can vary as well as lift and release characteristics of the pressure plate, so you again may have disengagemen issues.
