tick master HELP!!!
tick master HELP!!!
well, i just installed the master... looking at how to bleed it? i also bought the 4' 1 man bleeder not installed, i've read that the trans HAS to come out in order to install... is that true? PLEASE! some shed some light on it!
thanks,
Dan
thanks,
Dan
I don't see how you'll be able to thread the fitting without removing the trans. Maybe with a crows foot but it'd be a nightmare.
Here's what it looks like installed. See how deep it goes in and how you won't be able to get a socket or wrench on the fitting? My suggestion; if you're set on installing the bleeder order a clutch and slave too and install everything while you have the trans out.
