Mild FI Clutch+Gears? Anyone running specials?
2001 SS with a Procharger running 7psi. May upgrade to bigger cam and 317 heads later down the road. Intend to put 4:10 gears in while car is down. Would prefer to buy the complete clutch kit with slave and flywheel plus the gears and basic install kit from one vendor. Mostly a street car and it may see the strip one or twice a year tops. Any supporting vendors running specials right now.
The previous owner said 415hp at the rear wheels. Don't see more than 500-525 at the rear wheels in the near future. Stock clutch has 89K on it and I found a boost leak and now the stock clutch will not hold past 5000rpm. I do intend to run a 4:10 and 315's for rear tires. Just a fun street car with and occasional fun track day a couple of times a year.
I 'd go with our Level 2 and not look back. For a premium package with slave and 28lb flywheel it runs $749.99. You could upgrade to an 18lb flywheel to free up some more power to the rear wheels. We can also get you the gears and install kit, just give me a call and I'll get you taken care. Chris, 817-750-2000
