Clutch problem?
Clutch problem?
Sometimes when I am releasing the clutch about half way, usually when first taking off there is a clicking sound. It does Not sound good. Anyone know what it could be?
I was JUST about to post this same exact question. Kind of like clicking/smacking sound and the clutch feels sort of locked in and takes more revs to get it accelerating. (just pulling in the driveway for example or driving over a speed bump)
I had that same sound although mine where the springs on the LS7 pressure plate I had. Mine was to the point where the clutch wouldnt disengage period. Might be a spring on the clutch disc itself then if you can still shift gear. What clutch, master cylinder are you guys running?
Damn I can't even ask or learn from people who are having the same issue? I highly doubt the OP is using the same exact setup as me. To top it off everything on my car is shop installed.
