Cross member ??
Old 07-16-2011, 07:43 PM
95 mystic ls's Avatar
Default Cross member ??
Let me start off with thanks for the help. Now, I am changing my 95 A4 over to a LS M6. I stripped a wrecked 02 SS to get the parts for the swap. Went to put the trans cross member in and it doesn't work, the bolt holes do not line up. I need to know if the cross member fron a LTx car will work for this or do I need to buy a special one, if so who has one?
Old 07-16-2011, 10:56 PM
oldmano2z's Avatar
if the holes dont line up on the body maybe some adapter plates might help? bolt to trans and lift it into position you might just be able to weld the holes up and drill new ones? alot of this stuff is very forgiving if its not too far off.
Old 07-17-2011, 01:21 PM
One side is off by about 4 inches.
Old 07-17-2011, 03:53 PM
oldmano2z's Avatar
look at the cross member closely. when i did my changeover one was stamped auto and one is stamped man. i'm just saying that if its 4 inches off on one side check it thats what i found out with mine out of curiousity.< did i spell that right?
Old 07-17-2011, 05:55 PM
jmd
jmd's Avatar
LT1/T56 xmember will work.
Quick Reply: Cross member ??
