still bleeding, new clutch wont disengage
Old 07-18-2011, 06:36 PM
tarpley1's Avatar
Default still bleeding, new clutch wont disengage
02, firehawk
new southbend clutch (new gm flywheel, luk cover, kevlar disc, thier TOB,)
new slave, new master, and drill mod.
5 plus hours of bleeding, and it still wont fully disengage.
i have mytie vac'd it, gravity bled. and old fashioned pumped and crack bled it. going to try some other methods i've found on here this weekend.
just thought id vent, i just dont understand the tilted MC (air trap)
id rather push a wet noodle up a wildcats A$$. than do this jod again.
Old 07-18-2011, 07:10 PM
99SSJarhead's Avatar
have you tried putting the nose on jack stands or ramps to help level the M/C?
Old 07-19-2011, 06:20 AM
tarpley1's Avatar
this will be on the list for the weekend. it has been on the lift, (level) thanks.
Old 07-19-2011, 08:02 AM
HVYMTL's Avatar
Checkout the "Does my setup need a shim?" thread. Lots of useful information but it will get you scratching your head... and there's a chance you may need to take it all apart and get some measurements. It sucks, I know. Ask me how I know...haha I'm getting really good at getting my T56 out
Old 07-19-2011, 10:26 AM
SNLPerformance's Avatar
If you've bled it as much as you say you have then contact the guys at Southbend, I'm sure it's something simple.
Old 07-19-2011, 04:02 PM
tarpley1's Avatar
yeah i talked to them monday, the response was that it should't need a shim due to the fact that it is a GM flywheel, and a factory style LUK cover. they said to keep bleeding, and to try to find a pressure bleeder, im trying to find one local. no luck yet(one horse town)
i am also going to try the spark plug boot and line back into the resivior method. when i get back to work on it this weekend. any negatives about this method???
im not down on southbend, i install thier dual disc setups in dodge rams pretty often in our shop, they have a great product and good tech support.
thanks for your interest, will report back
Old 07-25-2011, 06:21 AM
tarpley1's Avatar
i got impatient tnis weekend, after bleeding for a few more hours, a took my new MC off and turned it into the adjustable stock type and, and had imidiate results, i feel like the distances are correct on the clutch/TOB.
just that a orielly auto MC didn't have the power to release the clutch cover??(just my guess). i only spent a bout 3min bleeding it, so i will do more bleeding this weekend,
car is totally different, solid clutch and 4.56's
Old 07-29-2011, 12:51 AM
NCal's Avatar
So, is it all fixed now? Are you able to shift it into gear during normal AND high RPM's?
Nick
Old 07-29-2011, 06:35 AM
tarpley1's Avatar
fixed!!, excelent low RPM shift. but im still breaking in the clutch, so i have only shifted it around 5,xxx RPM so far and it was fine in that range also, but we will see soon enough. im ready to thrash on it!!
Old 07-29-2011, 02:23 PM
NCal's Avatar
Excellent news. Thanks for the reply. Looks like there's an adjustable MC in my future.
Nick
Quick Reply: still bleeding, new clutch wont disengage
