What type of fluid are you using in your clutch M/C?
Old 07-22-2011, 03:06 PM
LilJayV10's Avatar
Default What type of fluid are you using in your clutch M/C?
What type of brake fluid are you using in your clutch systems? Currently I'm using ATE Super Blue that I got from Sam when I did my brakes. I checked the fluid the other day because I'm having some clutch/transmission issues and noticed that there were the little blobs in the reservoir. The fluid isn't burnt or black.
Should I be using something else?
Thanks.
Jason
Old 07-22-2011, 06:14 PM
mean_greenZ's Avatar
I used dot 3/4 valvoline.
Old 07-23-2011, 01:11 AM
99SSJarhead's Avatar
regular old dot 3 went in mine. Most everything I read here say stay away from 4 or higher as it'll eat seals.
Old 07-23-2011, 10:19 AM
ECU_Pirate's Avatar
This is what I'm using as well.
