Heat sleeve for clutch hydraulic line
Has anyone had any positive results from putting a heat sleeve on their clutch hydraulic line to keep it from being heated up by the exhaust causing a stiff pedal? I'm thinking of doing this but wanted some opinions first.
There isn't a negative to doing that, even if you've never had a problem. I even put some over my tick master line even though it comes with some already. It can be a bitch to slide it all the way up, but if it means you won't have a problem then it's totally worth it.
