Esiest way to remove pilot bearing?
I was doing the chisel method(after taping the bearing for 2hours and sharpening every screwdrivers I had, it was enough).
I will try this and give feedback, but I hope my chisel mess did not damage anything
http://www.youtube.com/watch?v=1xuR7T8G1Ys
That method is no where near as clean, quick and easy as using a good blind hole puller.
This set from Autozone is free to rent, and as long as you grab one that isnt all mucked up, works like a dream on even rusty bearings that are falling apart. Use it, clean it up, take it back and get your deposit. I ended up finding a used set on craigslist though because I found many other uses for it. Neat tool to have.
J.
J.
Works great, doesn't ding up the crank, and a few whacks w/ the slide hammer is all it takes to remove even stubborn factory pilot bearings.
