Fluid Capacity/Fluid Recommendations
Old 08-03-2011, 12:55 AM
99blkt/a's Avatar
Default Fluid Capacity/Fluid Recommendations
This is the first time I've pulled the tranny. Needless to say I had to drain it, I did this the hard way as most of it ended up all over the garage floor.
I was wondering what the capacity is on the t-56, I thought I read somewhere that its 4 quarts, is this correct? Also what brand/type of fluid is used?
Old 08-03-2011, 04:14 AM
z28camaro1996's Avatar
dextron 3 is what i used.
Old 08-03-2011, 03:52 PM
99blkt/a's Avatar
Been doing some more reading/searching, it seems the capacity is 3.8 quarts, can I just dump 4 in and be done with it or will .2 of a quart make a difference?
Old 08-03-2011, 05:09 PM
bigj2717's Avatar
Just open the fill plug and fill it till it start coming out the fill hole
Old 08-03-2011, 05:18 PM
99blkt/a's Avatar
All I can find locally is castrols dex/merc fluid will this suffice. It says it's for pre 05 gm automatics?
Old 08-04-2011, 01:31 PM
blue99fbody's Avatar
just dump 4qts in through the shifter hole. i run royal purple and have also had good luck from mobil 1 atf
Old 08-06-2011, 11:57 AM
99blkt/a's Avatar
Will castrol dex/merc work it's all I can find?
Old 08-06-2011, 12:02 PM
93BlackZ28's Avatar
Any Dex III ATF will work. Add fluid until it starts to come out of the fill hole.
Old 08-06-2011, 12:06 PM
peterock98's Avatar
GM Synchromesh fill to over flow.
Old 08-09-2011, 09:31 PM
tbag_skywalker's Avatar
Redline ATF in my transmission.
Unbolt the fill plug on the drivers side of the tranny and dump all 4 quarts down the shifter opening. Bolt the fill plug back in place once the .2ish quarts finishes spilling out.
Quick Reply: Fluid Capacity/Fluid Recommendations
