T56 Wiring help
Old 08-03-2011, 05:15 AM
6SIX6's Avatar
Default T56 Wiring help
Ok heres the situation im in. I have a 89 Camaro with a T56 behind a Small block carb motor. I need to know how to wire up the VSS to my autometer gauge. Also should I wire up the reverse lock out as well?? Not sure if I need it really.
If anyone can help me out let me know. Thanks
Old 08-03-2011, 12:10 PM
99SSJarhead's Avatar
Not sure on the first but unless you have monster triceps I'd wire in the reverse lockout. It gets old after a while having to use both hands to put the car in reverse.
Old 08-04-2011, 01:09 AM
the_merv's Avatar
What is the Imput on the Autometer Gauge..is it analog?
Old 08-06-2011, 01:59 AM
6SIX6's Avatar
I know its not a digital or mechanical one at all. This is the one I have
http://www.autometer.com/cat_gaugede...id=2789&sid=15
I need help on how the VSS wire would be run. The pigtail has 2 wires coming out of it but not sure what they connect to at all.
Same with the reverse lock out. 2 wires come out of the pigtail and have no clue what they would connect to.
Plaease let me know if you or anyone can help me out so I can get this done
Old 08-09-2011, 11:41 AM
bluenightmare's Avatar
i am running my lockout unwired, i like it like that because it makes 180's a lot easier
Quick Reply: T56 Wiring help
