Anyone know where to get a G6 F40 flywheel/clutch to fit a 5.3L 60 deg bell?
Just as it says Im helping a friend do a Fiero 5.3L swap from an 06 Impala and hes running the G6 spd manual because of the bell housing match. Ive seen other swaps out there running this so I searched around and came up bupkiss. Looking for a clutch solution that will hold around 350 whp
Andrew
Sounds like you may need something custom. What size flywheel will the G6 bellhousing accommodate? If it can swallow a standard 168 tooth LSx flywheel, then you can possibly use any LS1 clutch with a custom disk to match the splines of the G6 transaxle. The other thing to consider is how much room is inside the bellhousing and what kind of release mechanism is being used. I am assuming that it is some sort of hydraulic arrangement. Pictures would be helpful....
Andrew
Andrew
As for the rest of the build Ive already picked a cam for him and we have the supporting engine mods dialed thats easy for me now but these swap mystery's can become either very costly in the pocket, or very costly on the clock. One way or the other you gotta pay to play
Anyways thanks for the help Andrew I'll be posting about this more
Sounds like this might end up being an expensive proposition. One solution off the top of my head is to use an auto flew plate that was on the Impala, that will take care of the starter engagement. Then for the clutch you can use a Quarter Master 7.25" dual disk Rally clutch on a button flywheel (no teeth for the starter. It just bolts to the crank and mounts the clutch). Then you need to figure out how to release it, because the QMI clutch will need a radius faced bearing.
Andrew
Andrew
Sounds like a great start thanks! I was thinking dual disk as well simply from a holding stand point and the diameter limitations. Its not going to be the most radical engine but we're shooting for 350-75 whp and this guy is one HELL of a lead foot. He breaks everything he drives so the clutch will need to be overkill. Are those quarter master duals organic or ceramic or?
All this is based on the assumption that there is enough depth in the bellhousing. The FWDs always have very tight dimensions.
What year G6 is the trans axle from?
Andrew
Hmmmm his goals are to have a daily driveable type car so the sintered iron may not be ideal. The trans hasnt arrived yet ( its en route ) so I dont have answers to some of that but iirc its an 06 G6 F40 trans
This is of some interest here
http://www.v8archie.com/v8Archie/home.htm
I found more info here:
http://archives.media.gm.com/us/powe...2007/07car.htm
But nothing really helpful.
One really long shot is that the stock 3.9L v6 flywheel bolts to his 5.3L engine. If that works, then he is all set!!! Some of the GM writeups discuss similarities between the 3.9L engine and the LS1. It is a long shot, but that should be explored.
I also forgot to mention that Quarter Master also has a single disk 8.5" clutch. That clutch is available with an organic disk as well as a sintered iron disk. I had the sintered iron version in my RX7 (LS swap) and it was very street friendly and could be driven without drama.
Andrew
