A4-M6 swap master angle
So I have a 95 A4 Camaro I'm putting a LQ4/T56 in. When installing the pedals, I drilled off the bracket to install the master. After everything was said and done, there is a slight angle between the master cylinder and it's rod to the pedal. It's kinda hard to see in the pics, but it's there.
I don't have the engine, trans, or any of the other hydraulics in, and want to make sure this will be ok (or fix it) before I block easy access to the master.
So, my question is, will this be ok, or should I re-do it to try and get it perfect? Will this wear my master out quickly?
Hate to say it, but really the only way to find out is to try it.
I think you'll be fine, doesnt look too extreme from what i can see. The biggest thing to look for is if it gets worse when the pedal is pushed in. Does it bind at all? I believe they are designed to have some play, as the angle changes slightly as the pedal is pushed in.
I kinda figured I'd have to try it. It doesn't bind at all, if it does after I get it all together and bled I guess ill just tackle that when I get to it.
I'll take a pic of it with the pedal depressed, I didn't think of that.
Thanks
Thanks
