monster stage 3
monster stage 3
hey guys I bought my camaro off a guy that put a new monster stage 3 clutch in it and the thing always chatters in first gear some one told me to put in a polyurethane tranny mount in and I was wondering if this would really make it easy in first gear not to chatter
clutch
Im like 2000 miles over break in and also I cant change driving style with my pregnant wife in the car hard launches will make an early child birth lol I just want it to be right like it should be
Chatter can be contributed to a lot of things besides the clutch itself and driving style. If the engine or trans mounts aren't in good condition then I'd definitely replace them to solidify the drivetrain so it's not hopping around. The condition of the rear main seal is something else to consider, if it's leaking oil and contaminating the disc...not only is it causing it to wear faster, but it can cause it to slip and grab even if you're not meaning for it to. Another thing that can cause it to chatter if there is a glaze built up from excessively slipping it, the only way to get rid of it is to drive the car aggressively to knock it off(ie speed shift the car at torque peak or pop the clutch on the highway when you're wife isn't in the car
clutch
ya lots of people keep telling me to beat up the clutch so when I get it back I will beat it up a little bit or a lot a bit lol thanks guys Im also going to try the poly tranny mount
