GTO MN12 in 01 camaro
I'm about to drop in a LS2/MN12 T56 from a 05 GTO into my little v6 01 camaro. Had a couple questions about the hydraulics. Can I use the the FBody master cylinder from an 02 TA on this? The GTO master has a much longer pedal shaft than the fbody master. If I can use the fbody master, can I use the MN12 slave cylinder? It looks identical as far as the connector for the master, just want to verify though before i buy anything.
You putting the trans behind the v6 or putting the ls2 in there also? You can us the f-body master from an 02 ta, i would buy new oem slave cylinder f-body part number. Your gonna need a shifter assembly for a f-body t56.
And the F-body shifter needs the F-body offset shifter block.
https://ls1tech.com/forums/11689701-post2.html
