clutch will not engage
i recently installed a monster stage iii with light weight flywheel. after install, the clutch grabbed 1/2 inch off floor. rebled clutch and got a little better. while going through break in period the shifter started to grind a little going into gears. the problem gradually got worse. to the point where my clutch will not go into gear at all. with the car off it moves freely in and out. just put in new master cylinder and bled with mightyvac. slave cylinder is about 2 years old. the clutch had some chatter, i was told that was somewhat normal with a six puck disk. one of my mechanics insists its the clutch disk. the other insists its air in the lines. there is no fluid leaks. i don't know how much more detail i can give to get the best advice possible. i will try to rebleed tommorrow the manual way.
my tranny is a newly rebuilt t56 installed last october. the clutch has 800 miles on it and i just installed a new master cylinder this weekend. lost the o-ring on the hydraulic line that connects to the slave side. can't find the right one. size/material.
