Reverse Lock Out
Reverse Lock Out
I recently made some programming changes. Now I have to force through the spring to go to reverse when stopped. And the shifter will go to reverse while trying to go to 5th gear during driving. I looked back through the parameters and didn't see any way to turn off reverse lock out. It's plugged in and was working fine until I programmed it. Also, CAGS is programmed out, but goes 1st to 4th anyway, without the skip shift light. So I unplugged it. Any ideas?
Sounds like the rev & skip plugs on your harness are reversed/ in the wrong place. A quick reference is the correct plug matches the solenoid connector color.....White to white & black to black, although they will fit reversed/ in the wrong location.
