VSS Conversion from 1993 to 1995
Old 09-19-2011, 01:05 AM
kierantjones's Avatar
Default VSS Conversion from 1993 to 1995
Hey I was wondering what i need to do to get my 1993 VSS on T56 to work with a 1995 PCM system. Do i need to get a conversion box? what one would i need? any help would be appreciated. Thanks!
Old 09-19-2011, 08:22 AM
85MikeTPI's Avatar
You shouldn't have to do anything but maybe reprogram the ECM if the '93 is 11-tooth instead of the more common 17.
This was just discussed and would have turned up in a search....
https://ls1tech.com/forums/manual-tr...vs-1994-a.html
Old 09-19-2011, 10:25 PM
i know i saw that thread but i just wanted to know directly how to fix it
Old 09-20-2011, 11:15 AM
85MikeTPI's Avatar
You'd fix it the same way as was mentioned in that thread.
