best auto to manual pilot bearing conversion?
hello,
ive got a '77 trans am (yeah i know this is LS1tech but this isn't generation specific anyway), and it currently has a 200-4R transmission. i was thinking about getting a manual transmission (like a T-5), and so since my engine (olds 403) is equipped with an automatic crank i'd need a pilot bearing converter that would fit without removing the crank and machining it.
there are a few out there from mondello, dick miller, and supercarsunlimited, but i was wondering which one is the best, and will they work with a T-5 (or is this even a good idea)?
If you're not 100% sure the crank isn't drilled, I"d use longer bellhousing bolts and unbolt the converter / slide things back enough to check with a hand or a mirror.
Look into the CTS-V / LS7 Corvette pilot that is a larger o.d. and fits where a torque converter normally indexes in the crank. It's probably quite similar to Dom Jello's # PB-460.
thanks
Google "Mondello PB-460"
Their site gives some dimension information for the PB-455 as 2.00" o.d.
https://ls1tech.com/forums/manual-tr...-vs-small.html goes over the big & little bearings albeit verbosely.
455, auto, automaticto, bearing, conversion, crank, crankshafts, drilled, kit, ls, ls1tech, manual, olds, oldsmobile, pilot, swap, transmission
