throw out bearing?????
Old 10-06-2011, 12:03 AM
busa317's Avatar
Default throw out bearing?????
hi guys i went to the track friday and after my second pass the trans has been acting up 2x's it got stuck in 4th gear and would not come out
now it grinds going into 3rd almost everytime unles i like put it itnto nuetral 1 first then go into 3rd 4 th does just a little
it really wont let me down shift into 3rd at all without grinding
sometimes if im just sitting the in neutral and pust it into third gear but not moving it also grinds
also just sitting in my driveway in N i hear a noise like under the car if i push in the clutch the noise goes away thats why im thinking it may be a throw out bearing problem
i bled the clutch last night and that didn't help would a throw out bearing cause a grind into 3rd and 4th
any feed back would be very helpful thanks
Old 10-06-2011, 12:04 AM
busa317's Avatar
the cars is a 2002 ss bone stock no upgrades at all
Old 10-06-2011, 06:46 AM
garys 68's Avatar
Bad news, the parts in your trans are tuning even when in neutral. When you push the cltch in, they stop turning. Time for a rebuild.
Old 10-06-2011, 11:56 PM
busa317's Avatar
Driving home today i right into 3rd and 4th gear with no problem but i still cant downshift from 4th to 3rd
any input
Old 10-07-2011, 02:34 AM
99huggerorangeZ's Avatar
Sounds like a bad clutch or at worst a syncro...
Old 10-07-2011, 10:48 AM
SNLPerformance's Avatar
I'd start with flushing the hydraulic fluid and making sure it's clean/clear, then it wouldn't hurt to flush the trans fluid to see if that helps any. Report back if it does, good luck.
Old 10-07-2011, 12:01 PM
busa317's Avatar
Sorry about post #4 i meant if i double clutch the car it goes right into 3rd and 4th with no problem
Old 10-24-2011, 10:30 AM
Jr.Samples's Avatar
Maybe a bent/ broken 3-4 fork
Quick Reply: throw out bearing?????
